saw cut expansion joints in concrete highways how the sealent is appl.
how do they normally apply the sealent in saw cut expansion joints in highways , the silcone sealents and compression type
RE: saw cut expansion joints in concrete highways how the sealent is appl.
qmorr...first of all, the sawcut joints are not "expansion" joints...they are control joints for controlling the location of shrinkage cracks.  Expansion joints are created prior to concrete placement, not afterward.
The sealant that is used in them is typically not silicone...it is usually asphaltic based with polymer modification.  It is generally hot applied.
