creep analysis
creep analysis
In the case of a steel structure (30 stories) with a concrete core in the middle how can we consider the creep effect of central core on the structure?
my email: hakooo@yahoo.com
thank you
thank you
RE: creep analysis
mom@arrakis.es
RE: creep analysis
Your best estimates should perhaps be compared with laboratory tests on the concrete mix you will be using.
After this, you will probably still need to design the structure with hinge/flexibility etc that can cope with some variation from the calculated values.
RE: creep analysis
