Water in Cable
Water in Cable
I am doing a small power plant and a ran into a problem yesterday. When terminating the last run from the generators to the paralleling gear we found water ingress in one of the cables. The run is a 4" conduit with 8 350MCM XHHW conductors (+ ground). Operating voltage is 480/277. Part of the run is underground, part overhead. Out of all the runs from all the generators this one cable is the only one with water. The end with the water is at overhead portion of the run and after it was stripped back there was a slow drip coming from it. It sat coiled up in dry switchgear for more than 6 months before we went to terminate it yesterday.
My question is on a <600V system how much of a concern is this? We are replacing the entire run but I am wondering what the potential consequences could be if it were left like this. I realize in medium voltage applications this is disastrous but in this case if we purged the cable with nitrogen would it be OK or would cable life be considerably shortened?
RE: Water in Cable
RE: Water in Cable
RE: Water in Cable
We pulled all the old cable out today and the conduit was dry. The only explanation is that the water was there when delivered to the site. All new cable goes in Wednesday. The owner did not want to try purging.
RE: Water in Cable
William
