Reuse of steam piping
I believe that there is an ASME standard that addresses the re-use of pressure piping.  I now have the possibility of removing and re-installing steam piping for a 900 psi /850 deg system.  I am interested in knowing what standards or guides there might be.
RE: Reuse of steam piping
Hanelson,
You may want to have a look at ASME B31G - Manual for determining the remaining strength of corroded pipelines, a supplement to ASME Code B31 for Pressure Piping.
This is, of course, assuming that your system falls under the scope of B31.  Although, I can't imagine what other code it would be under.
solan,
       There are other international standards that cover Pressure Piping. It's not the sole domain of ASME B31.
