air extraction from large tank
I am trying to see if we have enough extraction points in a tank, the tank size is 12.5m by 40m with a depth of 7m the sludge level is 1.5m beneath the top. the tank is sealed and we have 1 extract point. extracting 2300cum/hr of air. is one extraction point enough or should there be more. how many??
thanks robin
thanks robin
RE: air extraction from large tank
nobody has answered this thread so I will give it a go......
- What is the sludge exactly? i.e. waste that creates methane?
- What is the exact purpose of the exhaust? life safety?
- If the tank is "sealed" with only extract point(s), little if anything would be accomplished because the extract fan would be attempting to create a vacuum.
A little more detail info. might help.
cheers,
- methane is probably present fan and control gear should be rated for the atomsphere - the exact requirements depends on the local code
- the area over which any exhaust connection exterts any influence (suction) is very small indeed. The best way t imagine this is consider the difference between blow out and a candle, and trying to suck it out.
- one exhaust point properly sized will create a negative pressure (ever so slightly below atomospheric). The exhaust air will draw fresh air in through the existing openings over the sludge surface and discharge into odour scrubber.
- consider all possibilities, high sewerage level, external flooding, etc.
some food for thought.
cheers,
In such a big tank I would support your idea of several extractions, nevertheless you should try to identify and control the air inlet points.
As noted above, be careful with the extraction fan motor rating ( if in the air flow) since the air mixture can be flammable.
Hope that helps.
PR
