Help with AutoCAD to MS Word interaction?
I'm working on a project that requires a user to select an option out of a combo box in AutoCAD that will then search a Word document, display that document, and zoom to the specified portion of the document.  I can get Word to appear with the appropriate document but heretofore have been unable to make the program "zoom" to the desired portion of the document.  Any suggestions?
RE: Help with AutoCAD to MS Word interaction?
Quck and dirty you could use SendKeys to initiate a find, more properly you should use the Work Object model, which is powerful but requires quite a lot of learning
To get a quick idea of how to access the Word Object Model, just record a Word Macro. You can then edit the Macro to see how it works and modify to suit
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
