Torque vs RPM carachteristic in diesel engines
Can anyone oblige as to what are the predominant factors in engine design that determine the shape of the above in diesel engines, both for NA and turbocharged types ?
Or put in another way, if one wished to push the max. torque developed in a turbocharged diesel from the original 1600 RPM to say, 2000/2100 rpm, what would be the principal modifications required ?
RE: Torque vs RPM carachteristic in diesel engines
Can you be more explicit as to how ignition timing and the turbo boost map need to be altered ?
It would be expedient to do so for a pleasure boating application, viz., to have the max. torque developed close to cruising rpms (2000/2200 rpm).
Work boats could do with the standard road-vehicle torque peak at 1600 rpm.
If you look up the torque vs rpm carachteristic curves for Cummins, Hino, Mercedes etc. you will notice that the marine engines have their max. torque developed at higher rpm than their road-vehicle counterparts.
A host of after-market shops tailor petrol-engines to the customer´s wants and needs, but diesels are till today shrouded in secrecy.
That is seemingly why the engines in question have their torque vs rpm carachteristics "drawn out" to peak at higher rpms, as registered on a dyno.
In reality, the engine hp vs rpm curve is normally above the prop hp vs rpm, thereby enabling the vessel to accelerate if need be, when until finally the two meet at the rated power point (no reserve power left).
In mechanically controlled engines, the HP/rpm curve slopes upward, and is convex upward, until it meets the prop power requirement curve, which in marine application data sheets is always drawn in as a cubic curve.
In electronically controlled engines, the HP/rpm curve slopes upward over the first ~half of the usable rpm range, at which point it becomes perfectly flat. I.e. an electronically controlled marine engine will run at constant power against a dynamometer while above what would otherwise presumably be its torque peak.
I don't see how it makes a difference. In a boat you can't actually get above the prop curve anyway.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
Do you necessarily have to go the electronic injection route and discard mechanical injection, to push out the torque peak from 1600 to 2000/2200rpm for marine applications ?
Don´t know, but most current marine diesels are derived from their truck counterparts and achieve the desired result by retaining the mechanical injection (duly altered, of course).
reduction of volumetric efficiency. The designers of that particular engine have set those parameters for a specific reason. If you want to raise the torque point you need to raise the volumetric efficiency, and do like Mike says.
In essence you are increasing the HP by doing such.
Say you have 100 lb.ft. at that 1600 rpm point. Thats 30 hp. And now you wish to raise that torque point to
2000 rpm and for argument sake its still 100 lb.ft.
Now the hp is 38 hp. So its just a matter of more air and more fuel, and setting the governor for that rpm. The reason Mike mentioned timing is because as you speed up the mechanics, and since the chemical reactions don't follow, you need to advance the timing as you speed things up.
Most likely if you icrease air and fuel your power increase will be more than in the example. If the components in the engine have been optimized for the original power settings, you will be drasticly reducing the life of the engine.
I am all for making more power at a lower per unit cost (max. torque point) in a region of the power band where the user is likely to spend most of the time.
NA engines see vol. efficiency drop off at higher engine speeds due to deterioration of engine-breathing dynamics.
Turbocharged engines can artificially locate the peak vol. efficiency at a desired rpm, by judicious choice of turbocharger and boost/fuel/timing map.
Umpteen aftermarket outfits perform such feats, day-in and day-out, with petrol engines but very few, if any, on diesels
Paulista, changing the ignition map on a diesel won't get you very far at all :)
Diesels do not have the sensitivity that gas engines do regarding stoichiometric air/fuel ratios so the strategy, crude as it may be, is to run maximum efficient boost, and turn the fuel up perhaps with a shot of nitrous oxide to assist in charge temperatures and complete burning.
To move the torque peak higher in the RPM band, there's several ways to go about it but an extrude honed intake and some porting on the cylinder head would help.
It will. Because its a positive pressure forcing
its way in. In an N/A application there is a time issue for cylinder fill. And that is why the racing cam industry
has thrived. Agreed a restrictive issue, valve timing, and size being one of them.
With a supercharger you are "packing" more air in. So what is happening is at a given speed where say VE was falling off with N/A, because the piston has to start moving air by sucking it, now there is a pressure head of air to help force the piston down and then pack some extra in. So
instead of being some number under 100% VE you now have some number OVER 100% VE. You need to compair the airflow
requirements of the N/A, to what the new airflow is to the
supercharged engine. If that airflow exceeds the cubic (what ever units) displacement, then you are over the 100% VE mark.
Anyway you may fail to see it, but the engine has no problem seeing it. Cause that is why any form of supercharge will produce more power than an N/A. Recip engines are air pumps, and the more they can get the more power they produce. Even with hp losses from a mechanical supercharger, it will still out produce a similar N/A engine. If it didn't the OEM's and drag guys wouldn't use
them.
After all, claiming some huge increase in VE by doubling the power into a supercharger scarcely seems a level playing field unless that power is taken into account.
Cheers
Greg Locock
"Paulista, changing the ignition map on a diesel won't get you very far at all :)"
If you retard ignition timing on a diesel, it may overheat in a most violent fashion (I have personally witnessed this!)
True, excess air is always present for combustion, unlike petrol engines.
So where do I look (book ?) for reliable data on tailoring the torque vs rpm characteristic ?
GregLocock wrote:
"After all, claiming some huge increase in VE by doubling the power into a supercharger scarcely seems a level playing field unless that power is taken into account."
Granted, especially as the supercharger taps power from the useful engine output.
This would not hold if a turbocharger that runs on spent engine gases were used, unless the thing was so badly designed as to restrict the exhaust process and thereby actually lower power output. Right ?
There is a NET BENEFIT, if correctly done. The mechanical efficiency goes up.
In supercharging setups, an increase in sfc should be the normal outcome, aside from the augmented power output.In extreme cases, "the law of diminishing returns" may come into play.
However, for reasons that are no longer clear to me, turbos on diesels do tend to improve the overall efficiency of the system, whereas for SI engines they rarely help.
So, on a diesel you can get more than you lose from a turbo, but on an SI you'll still be less efficient than you were, although probably not as inefficient as when a crank driven supercharger is used. Here's some results for a production car
Supercharged N/A
City (litres/100km) 16.1 11
Highway (litres/100km) 12.2 6.6
Power kW 235 155
Torque Nm 465 305
s/c specs from h
Turbocharged N/A
Average fuel economy
(litres/100km) 12.9 11.5
Power kW 240 182
Torque Nm 450 380
Figures from www.ford.foa.com
Since these are fixed driving cycles the extra performance of the s/c and t/c models is not really a factor in the increased fuel consumption. There is a slight difference in weight, both the faster cars are higher spec.
Cheers
Greg Locock
Can they guarantee that fixed-driving cycles preclude the un-leashing of latent power by the test-drivers of the vehicles ?! Must choose very controlled types.
I have noted that t/c consumption figures are closer to n/a and that s/c is a long shot away.
One of the possible causes that springs to mind for the not so encouraging results of t/c in petrol engines, could be the higher probability of DETONATION ("knock") of the fuel/air charge at higher cylinder operating pressures.
Also, airflow and fuel flow are not independent parameters, as they are in diesels, although the available exhaust gas energy to drive the t/c is much higher in petrol engines than in diesels.
In fact, t/c caught on more after EFI established itself in the trade, as carburreted engines were tough to t/c.
Direct-injection diesels are immune from DETONATION(duel-fuel diesels that ingest air+natural gas and use pilot oil-injection are NOT)
I'm pretty sure you meant to say injection timing, but you've made the same mistake a few times so now I'm starting to wonder... (What kind of spark plugs do you use in your diesel?)
CI engine compression ratios are significantly higher than SI, there's more free energy available for reclaimation by a turbo.
Manufacturers' use spark-retard knock sensors and lowered compression ratios in turbo petrol engines to limit detonation, both of which hurt the BSFC.
Regarding Volumetric efficiency, I was under the impression that VE was a measure of breathing efficiency independant of density calculated by dividing the actual volume of air in the cylinder by the total displacement of the cylinder, e.g. (350cc)/(400cc)=87.5%
Even if you change the density of the intake charge, peak torque will still occur at the same RPM, VE hasn't changed.
The benefits of the denser intake charge are mainly dependant on the intake:exhaust pressure ratio, how much backpressure does it require to generate X-psi on the intake side?
As the volume of air is always the same, it is actually the density or mass that changes with VE, or to be more precise, the volume that that mass of air in the cylinder would be at ambient temperature and pressure vs the volume of the displacement of the piston in the cylinder.
Undoubtedly it is possible to drive in a more, or less, economical fashion whilst staying within that band. I don't know how that is regulated, in fact I doubt that it is.
Almost all objective testing of cars relies on the integrity of the people involved.
Cheers
Greg Locock
There is always some scope to optimise some conditions while staying within the test method parameters.
"I'm pretty sure you meant to say injection timing, but you've made the same mistake a few times so now I'm starting to wonder... (What kind of spark plugs do you use in your diesel?)"
Slip of the tongue.
BenDutro wrote:
"CI engine compression ratios are significantly higher than SI, there's more free energy available for reclaimation by a turbo"
Regardless, the enthalpy of exhaust gases in SI engines is way above that of CI engines. For the same reason, the t/c in SI engines often needs to be a ball-bearing type in order to survive the enormous heat.
Recall also that SI engines loose to CI engines when it comes to mechanical efficiency, as more heat is lost to the surroundings.
GregLocock wrote:
"Almost all objective testing of cars relies on the integrity of the people involved."
Also seconded by Patprimmer. Not the integrity of the test drivers that I was getting at, but a natural overshoot-type phenomenon, viz., the tremendous difference in the responsiveness of the test vehicle and the time it takes to start driving it "normally". Jump out of the driving seat of a 4-banger into a V-8 and you will see for yourself! Nevertheless, the test figures that were supplied actually corroborate with what is predicted by theory.
While exhaust back pressure rises, so does boost, and the whole mess then becomes a double compound system, with two stages of compression and two stages of expansion.
The trick with a turbo is to match the turbine Rpm, developed internal shaft power and pressure ratio as exactly as possible to the compressor requirement. The whole turbo will then reach an efficiency peak at some particular mass flow.
The turbo has absolutely no idea what the size or Rpm of the engine is, it just sees flow. So you size the turbo to suit the optimum flow at the desired torque peak.
That can skew the torque curve of an unblown engine, to move the raised torque curve either way depending on the application.
Turbocharged gasoline engines are usually hampered by a slightly reduced static compression ratio, and slightly increased exhaust back pressure, so light throttle fuel economy might not be so good as its n/a equivalent.
Diesels have no similar limitations. Provided there is efficient and complete combustion, and no over-fueling it should have a pretty good fuel specific either n/a or turbo.
Diesel torque is primarily a function of the quantity of fuel injected until you reach the point where you have consumed all the intake charge air. So the fuel injection system (mechanical or electronic) delivery curve can be tailored to give any desired shape up to the "smoke limit". Many diesels are sold with their power delivery curve optimised for their particular application. There may be other changes made to optimise efficieny such as turbo A/R, injection timing, etc. but these are fine tuning compared to fuel delivery.
When I worked at Mack Trucks engine developement laboratory, we used the same 6 cylinder block for anything from 200 to 375 hp ratings. There were many differences in the tune of these engines including compression ratio, turbo size, pistons, ring packs, etc. The higher power engines got piston cooling jets, main bearing tie plates, bigger oil coolers, etc. So it is not just a matter of cranking up the fuel but that is the primary difference in the power. You could buy the low power engine & crank up the fueling to get almost the same power as the high power version. Of course, it wouldn't last very long.
".....So you size the turbo to suit the optimum flow at the desired torque peak."
dgallup wrote:
"Getting back to the original question about the shape of the torque curve:
Diesel torque is primarily a function of the quantity of fuel injected until you reach the point where you have consumed all the intake charge air. So the fuel injection system (mechanical or electronic) delivery curve can be tailored to give any desired shape up to the "smoke limit". "
Now the pieces fit, so it seems !
1. Choose a turbo that will give you the required air charge/mass at 2000/2100 rpm
2. Tailor your fuel delivery accordingly, keeping the latter below the smoke limit.
There is this ex-Cummins engineer who was employed at the factory for 30+years and has produced a cheap kit (US$ 200-300) for taking a 6BTA from 170 HP (in the older Dodge Rams) to 240 HP in just 2 hours of work ! I shall post his bearings on the Internet as soon as I am done with this post.
Instead of just "turning up the fuel delivery" on the BOSCH P7100 pump as most mechanics do, he substitutes the original "fuel-plate" in the pump with his own proprietary design (supplied in kit). Another part that is also supplied and replaces the OEM part is a hose-connector on the fuel-injection pump which connects it to the turbo´s compressed air delivery, and which is used for metering fuel over the whole range of boost.
No doubt, the 6BTA is capable of 240 HP, a rating that was down-sized for early Dodge Rams, in order to keep the powerplant and drive-train compatible with each other. So taking it up from 170 to 240 HP is basically just tweaking it - correctly !
In practice, it may require at least changing the compressor and repeated trial-and error runs, to increase the power from a 4-cylinder turbo-charged diesel rated at 150 HP/2600 rpm , to say, 200 HP/2600 rpm.
Finally, why do electronic-injection diesels ("common-rail") make from 30-40 % more power than their prior mechanical counterparts ? Also, the torque-curves of the former are largely flat over a wide rpm range, unlike the mechanical that have a varying torque curve with a peak somewhere in the range.
www.tstproducts.com/
The exhaust turbine more or less fixes the turbo Rpm versus flow, and changing the compressor size will only have a small effect on boost pressure and flow, unless the changes are really large.
On the other hand, a small change the exhaust turbine a/r will significantly change turbine Rpm for any given flow. That can have a more dramatic effect on the compressor operating conditions than just changing the compressor specification.
But,yes, turbocharging - and force feeding an engine - can compensate for loss of vol. efficiency.
I think the reason for lowering the CR in marine diesels is to lower the mechanical stresses on engine components, granted that marine engines operate at higher loadings than vehicular ones.
Imagine you could build in an infinitely high compression ratio with zero combustion chamber volume. All the exhaust would be pumped out mechanically, creating more space for the induced air on the next cycle.
It also effects a lot of other things once the valves are shut, but those are other issues.
Mike
Max. torque synonymous with max. cylinder pressure seems OK.
But not quite sure if I agree with max. torque coinciding with max. heat. In fact, I think the inverse should be true, that is, max. torque = min. heat being rejected, and this point generally coincides with the minimum of the sfc curve.
Obviously, though, if you push out max. torque to a higher rpm, then you will be generating more power at higher rpm than you were prior to the modification.
More output power being generated suggests more heat rejected to the surroundings, but nevertheless, proportionately less heat per unit of output power than at any other operating point.
Right or wrong ?
