Large diameter FRP pipe
I would like to use FRP for the final casing of a well I am designing. I am having trouble locating an FRP manufacturer that makes 24-inch diameter FRP that has a threaded connection. The casing will be set to a depth of approximately 2,800 feet and must undergo pressure testing every 5 years. Can anyone point me toward a manufacturer of 24-inch diameter FRP?
RE: Large diameter FRP pipe
http:/
Try these.
Good Luck
You may have to run down the Ameron rep in North America.
What is the bottomhole temperature going to be like? It could effect your pipe.
