Foundation cracks in Slab on Sand
Why would a slab crack that is built on sand and is 12 yrs old. The cracks appear to be active (as in showing signs of movement). The rear of the structure is approximately 5 feet from the canal. Visual inspections of the bulkhead did not show signs of erosion or washout. Is it washingout under the water? I do not know? Typically there should be piles under the rear of structures that are that close to the water. So what would you do? or what would you tell a buyer without having to worry about the seller sueing you?
Someone educate me about sand. I always thought it was the best material to build on. Thanks in advance for any advice or source of material.
RE: Foundation cracks in Slab on Sand
Being so close to the canal, the water table has definetly jumped up and down a few times.
What might have caused a low water table? Construction work up stream that may have reduce the flow to an abnormlly low level. Belive it or not, even trees will have a sgnificant effect on local water table but probably not in the case. Increased water table is not a concern for you in the case, unless the water came gushing out of the crack, i.e., lifted the slab. There would be signs of stainging or rust on some mechanical in the basment due to high humidity.
Good news is that if the problem is related to low ground water table, the settlement is over - for now. The slab wont drop anymore unless the water table drops further again.
The slab won't bounce back either because the voids squeezed in on each other and won't allow the water back in to allow the soil/slab to rise.
More serious is the concern with the bulding foundation. have good look to see if any repair work has been done which may be a sign of more serious trouble. If the basement is finsihed it will be ahrd to tell from outside.
If you don't want to marry this house then I suggest spending a couple hundred bucks on a geotechnical engineer to get some peace of mind and transfr liability. That's my recommendation - get an engineer. You're client would appreciate that. Don't let it become your problem.
This is very interesting about the water table. I have read information about it before. I will definitely keep it in mind for the next similar project.
These questions should be answered before looking at the sand as the culprit. It could be just poor quality control in the treatment and placement of the concrete!
