Line Load on Wall
Line Load on Wall
How do you normally apply line load on a wall? I added a dummy frame element at the top of the wall and applied the uniform load. However, it gives me a warning that the load has not been transfeered. does the line's property need to be modified?
Thank you
Thank you
RE: Line Load on Wall
DBD
So if you want to get a sheet of glass that's sitting on a wall to register, the reactions from the glass must end up at the nodes of the wall. Make a fake beam, unless you want to determine a nodal load.
