sections in SW 2004
sections in SW 2004
Ok, I have many assemblies where I have a circuit board enclosed in a box that's about 4"x2"x1" with a cable that is up to 12 feet long. What I'm looking to do is to be able to model the cable true length. The problem is that when it comes time for assembly prints, the cable is so long that no details of the box can be seen because it's so zoomed out.
What I'm looking to do is to do a cut-out section, but SolidWorks doesn't appear to do this. Anyone have any ideas? I could do two configurations and two views, one for the box construction, and one for the cable hookup, but I'd prefer to have everything shown at once. Any ideas are much appreciated.
RE: sections in SW 2004
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
FAQ371-376
FAQ559-1100
FAQ559-1091
FAQ559-716
There is a cut-out section view but it does something different than what you seem to be after.
Another alternative is an assembly cut which could be suppressed in a config.
Fill what's empty. Empty what's full. And scratch where it itches.
1) Place the full length view of the assy in a drawing ... do the Broken-out section that you want on the box, then do a Detail View which includes that Broken-out section.
[img=http://img204.exs.cx/img204/9108/brokenout4yx.gif]
2) Place the full length view of the assy in a drawing ... use the Insert > Vertical Break feature to "shorten" the cable length so that the sheet scale can be made full scale, then do the Broken-out section.
[img=htt
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
Happy it worked out.
Chris
ctopher's home site
FAQ371-376
FAQ559-1100
FAQ559-1091
FAQ559-716
