Nail Gun Testing Fixture, designing fixture and counter
I am designing a test fixture to test the life of a seal (I am a seal engineer) inside a nail gun. I have little experience in designing test fixtures and I need your advice.
Here are the criteria:
1. Nail gun must be fastened or clamped tight.
2. Use pneumatic actuator, rotating motor other mechanical means to mechanically trigger the nail gun. Please advice on this.
3. Need to count the number of cycle. How?
4. Nail gun generates loud noise and vibration, what material should I use for the Housing? I am thinking about aluminum. Any advice.
If you have concept sketches please send them to me at bogiedreamer@gmail.com .
Thank you very much,
Bogiedreamer
Bogiedreamer
RE: Nail Gun Testing Fixture, designing fixture and counter
As for the enclosure, use whatever is handy. Plywood would work just fine, just make sure that you have something durable where the nails hit (unless you are dry-firing). Line the outside with acoustical foam or a quilted sound deadening blanket and go to town.
Hope this helps.
Not sure what you mean by "housing". An enclosure for the test set up? If so, it could be built of plywood unless you are concerned about flying debris when the gun fails. Wood is a good insulator for sound and temperature.
It seems to me that you might have some test mechanism design issues with cycles per time if you want to make certain that each cycle is initiated at full line pressure. Maybe you have already addressed this but my experience with air tools leads me to think that there are areas of temperature, lubrication and load that should be at least acknowledged in your study.
Griffy
Another reason for doing so is that then you can use the gun's motion to trigger a counter. Done right, such an arrangement should cause the counter to stop indexing when the gun stops firing properly.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
thanks for your input.
I have sucessfully designed a cam(basically a round disc attached to the shaft with a finger at the circumference sticking out and trip the trigger and the disc rotates) to trigger the nail gun. The nail is firing empty.
Now I need to know what type/model/brand of counter can I use to count the number of cycle? I am looking for a counter with a lever that can be trip by the same "finger" that activates the nail gun although they don't have to be activate at the same time, could be half a cycle different.
thank you very much.
Bogiedreamer
Get a good one and keep it around the lab.
Veeder-Root has been around for years.
http://www.dancon.com/index.sht
thank you very much. exactly what I am looking for.
Bogiedreamer
