Multi Arc Sweep
Multi Arc Sweep
I have a swept surface and the main curve of the swept surface is composed of tangent arcs. This means that the surface showed the coinicidental points that they attached together. This created problems down the road with picking a offset surface, because it picked a section and not the whole face. I went back and changed the main curve to splines, but is their a command to fix that without having to change the main curve of the swept surface?
RE: Multi Arc Sweep
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
FAQ371-376
FAQ559-1100
FAQ559-1091
FAQ559-716
RE: Multi Arc Sweep
RE: Multi Arc Sweep
Fill what's empty. Empty what's full. And scratch where it itches.
RE: Multi Arc Sweep
If you need only some of the faces of the swept feature, then you'll definitely need to select multiple faces.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
