fastners removes fully defined status of assembly
before i added fastners, i had all the parts in the assembly fully defined. ie. you couldn't move any of the parts and the property manager had no "(-)" next to the parts.
after i use smart fastners to "populate all" the holes in an assembly all the parts have a "(-)" next to them to tell me i have to mate them in order to fully define them in the assembly. but i cannot acctually seem to move them and when i enter another mate it always overdefines it!
[i seem to have found a work around though - i have to add any mate to OVERDEFINE the assembly, then just delete that mate. then it fixes the "(-)" issue]
is it a bug or am i doing something wrong or ???
RE: fastners removes fully defined status of assembly
Mates have been acting pretty weird in 2005. I'm have problems editing a simple concentricity mate. I usally have to delete it and re-create it.
Macduff
Senior Designer/Checker
Dell Precision PWS370
Pentium(4)2.80GHz
Ram 2.00 GB
SW2005 Pro SP 1.1
XP Pro SP2.0
NIVIDA Quadro FX 1300
Are you sure that they are totally locked down.  The fasteners may be coincident and concentric but nothing to keep them from rotating.  I can only guess that the answer is not what I just said but other than that it's nothing Ctrl-Q can't take care of.
KM
i was sure they were locked down before.
and Ctrl-Q worked a treat! Thanks!
(i had tried the rebuild before... didn't know about force rebuild.)
