Relay for switching off 310rmsVAC
I want to find a relay that ideally is normally closed (but could live with normally open) that would switch a 310 rms VAC 650 HZ at about 1A.
The switching frequency is variable from 5 to 20 per second.
This is to control an electoluminesent light off on demand.
Am rather stumped.
Help would be appreciated.
Regards:
Gins
Inappropriate post?
If so, Red Flag it!
Check out the FAQ
area for this forum!
RE: Relay for switching off 310rmsVAC
Try Electronic Controls, Inc in Conneticut.
need better specipication/description.
<nbucska@pcperipherals DOT com> subj: eng-tips
read FAQ240-1032
Thanks for all your interest and help was able to get the project working with some high voltage relays from Crydom.
Many thanks
Gins
