Create a Grip
Create a Grip
Hi, I am searching for a tool that can move diffrent objects to a specific layer. Move all sketchs to layer 20, all datums to layer 21 all components to layer...
Is it difficult to creat own ones or is there already someone that has this grip?
Best regards
Peter Norrblom
I am running NX3
Best regards
Peter Norrblom
I am running NX3
RE: Create a Grip
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
RE: Create a Grip
pnom,
Please be aware thet while the SolidNX layer tool is an excellent tool, it requires a UG/Open Execute license. It is NOT a GRIP program.
Also, as an aside, I have spoken with the author of the program, and we found out yesterday that this tool works in NX3. I am not sure if he has had a chance to update his website to reflect this fact.
Good Luck!
Chris Cooper
Cleveland Golf / Never Compromise
www.clevelandgolf.com
www.nevercompromise.com
RE: Create a Grip
Jonathan T. Schmidt
http://www.schmidtmotorworks.com
RE: Create a Grip
Ben Loosli
Ingersoll-Rand
RE: Create a Grip
I guess you meant to say "can't pickup". Which enitities are you concerned with?
Jonathan T. Schmidt
RE: Create a Grip
The NX layer tool needs some interaction from the user, you have to select objects that you want to change.
I have created a macro and think it will work fine.
Thanks for the answers.
//Peter
