Simulation of non-linear thin material in IDEAS for defects
Hello everybody,
I would like to know what are all the factors effecting the resonance frequency of a structure(non-linear material in particular).
I am using the following properties to define the material in IDEAS , which is paper for food packing purposes.
Youngs modulus - 2755 mpa
bulk modulus - 1059 mpa
poissons ratio - 0.3
mass density - 684 kg/m^3
Unfoutunately i get all the resonance peaks less than zero when i derive the FRF for the structure, which does not correlate with the experimental results.
what else do i need to define for the material to get the correct frequency peaks? Is it damping or stifness or what?
Thanks in advance
Mirza
Thanks in advance
Mirza
RE: Simulation of non-linear thin material in IDEAS for defects
ideas needs a solid to give weight mass ect.
no free edges or open surfaces.
mr.product
My part is a paper clamped at both the ends.
I think that would make it manifold.
I did create a very thin solid and given the mass density but not the weight.
How do i make sure about no free egdes or open spaces.
Mirza
