CAD Collaboration tool
Hi All,
I work for a government organization - we are assessing a new technology that enables online collaboration with 3D and 2D CAD files (from any CAD program). Users log onto a secure website where 3D images and animations can be uploaded. Users can rotate, disasseble and assemble the components, zoom-in and out, mark-up the drawing and talk (VOIP) and text message. All of this occurs in real-time.
I can provide a more detailed description if needed (please just ask)....
From this description - can anyone provide any comments on the need for this techinology in product engineering or manufacturing environments? Also what features/specifications are important to engineers with respest to online collaboration technologies?
Thanks for your help and time,
RE: CAD Collaboration tool
The biggest obstacle is also the feature/spec that is most important to engineering departments that attempt to work this way: Standardization
There is no established standard to CAD modeling, there are few file formats (dxf, step, iges) that work well on all software systems. To accomplish this in todays worlds most collaborative designs require common software to be effective.
Another highly important feature is security, encryption, validation (who made the change, when, why, with what permission).
Fill what's empty. Empty what's full. And scratch where it itches.
Many small businesses (one-man shops) are teaming up to be a collective of small businesses that are capable of handling large projects (sorry, I don't like the word "synergy"). In some cases, we're located across the country and without the financial resources to travel on a whim. Small businesses certainly can't afford major video-teleconferencing centers and the state-of-the-art computer-based video is often not good enough. The capabilities about which you speak would be excellent.
Garland E. Borowski, PE
It is our primary means of discussing the design. One example is that the CAD data is linked to a problem database, so we can right click on a part and it creates a form to fill in.
If I were you I would spend a lot of time making the dimensioning system bulletproof and easy to use.
Cheers
Greg Locock
I agree with both aamoroso and GregLocock on their comments for model standard(s), security administration and for dimensioning/detailing the model. At one of my previous places of employment, we looked at using a "viewer" for production purposes that would show animations of the assembly procedure. Unfortunately every time we wanted to go outside the "canned" demo, things began falling apart. You will have a challenge in accommodating the potential complexities of models used.
Some questions:
Is the technology targeted primarily for mechanical design collaboration or is it flexible enough to include electrical/materials/optical/chemical etc. modeling as well?
Do you envision the capability to link to indirect sources of information such as test result files, cost quotations, quality data etc.?
What type of analysis/reports could be mined/generated from this?
What user operating or server systems might be supported and how powerful should those systems potentially be?
Good luck and regards,
modulator, you're saying that you have a technology that reads any CAD file? That would be amazing!
--Scott
For some pleasure reading, try FAQ731-376
Try http://viecon.com/en/default.asp
Ciao.
What is your system called?
What does it cost?
ht
is, I think, relevant
Cheers
Greg Locock
is a better reference.
Cheers
Greg Locock
There is a free JT viewer: www.jt2go.com
The Vis suite starts at ~$500USD for a light user, and climbs to ~7500USD for full VisMockup, with many steps in between.
