Calculating pressure drop across an orifice
What is the equation that I need to properly calculate the pressure drop across a restrictor orifice?
I'm using Fuel as the media.
RE: Calculating pressure drop across an orifice
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
Thanks in advance.
Good luck,
Latexman
John
Good luck,
Latexman
It would also be helpful if you stated what fuel you are referring to: gas, fuel oil (which one), coal, coal slurry, refinery off gas, hydrogen, etc.
