oxy-acety hoses test pressures
What is the test pressures of hoses for axy-acety welding and what is the minimum length and diameters of the hoses to be used?
RE: oxy-acety hoses test pressures
Hi there cemcayan,
Saw your question and popped to the w/shop-I have pipes there with a 10mm(3/8")inside diameter 12metres in legnth
with a test pressure of 20bar(around 280psi)
Legnth and bore sizes should be to your personal preference.
However-strongly suggest Flasback Arresters!
Good luck
TWWeld.
