Library Feature - Thread
Anyone been able to get a library feature to work with the helix command? It was stated that this was an enhancement to 2005.
Trying to create a library 3d hole thread that I can drag and drop onto the model. I normally don't do this but when you run rapidprototypes, it helps to have the threads modeled.
Any macros out there that does this?
Jason Capriotti
Smith & Nephew, Inc.
RE: Library Feature - Thread
Jason,
The SW2005 API Help has a pointer to a Spring `Macro Feature' that you can download.
http://files.solidworks.com/api/examples/00000/0300s/0349/example.htm
http://files.solidworks.com/api/Downloads/00000/0300s/0349/springapi.swp
You should be able to change the profile to a diamond rather than a cicle, and do a boolean subtract after the feature creation to cut a cut thread effect instead of a spring.
FYI,
DesignSmith
www.DesignSmith-Services.com
