How to set export units for a DXF file?
I have a .Catpart file that was done in inches.  I need to create a .dxf file of the profile, no problems exporting it.  But when I go to check it, it seems that my .DXF file seems to be exporting as mm's.  (My part comes in much smaller)
Is it my importing or exporting that is resizing it?
I would like to understand how I can set my units for a .DXF file.
Thanks again for any help....
-BsurfN99
RE: How to set export units for a DXF file?
Tools, Options, General, Compatibility, DXF tab, Unit of the File.
I overlooked that setting, being that I was exporting.  In my quest to fix this issue I found that if I set my paper standard to ANSI that worked as well.
ASME = mm
ANSI = inches
Thanks again.
-BsurfN99
