Problem with disappearing pickbox in MDT2005
In MDT2005 the pick box dissapers off the screen in paper space and model space after the model has been created. It also does not appear in paper space when the drawing is projected. It seems to be OK during the model sketch proceedur, only disapearing after extrusion. The MDT2005 has the service pack 1 applied, running on XP PRO, Pentium 4, 700 Meg Ram. I also have MDT6 loaded on the same machine, which does not have this problem. I suspect that it's one of the settings that is causing it, but I am not sure which one. Can any one help?
