Parts/Assemblies Checking into Vault as "Standard Library Documents"
I am checking in parts and assemblies (created by someone else) to the vault. But instead of showing up as parts and assemblies in the vault, they are showing up as file type: "Standard Library Document". I checked in some of my own files earlier today without incident. (I'm using SW 2005 SP 1.1)
Any ideas as to why this is happening, and how I can reverse it? I know that toolbox parts have an internal flag that can be toggled on and off- is this a similar situation?
Rebecca
Rebecca
RE: Parts/Assemblies Checking into Vault as "Standard Library Documents"
Are you checking them into the right Project folder on the inital check-in? Also, Right mouse click on the top assembly and you might be able to change the Project file and it's children there.
I'll do a little more research on this
Best,
Macduff
Senior Designer/Checker
Dell Precision 370
SW2005 Pro SP 1.1
XP Pro SP2.0
NIVIDA Quadro FX 1300
One more question, were these parts created from toolbox and renamed? If so, you have to down the toolbox property link.
Macduff
Dell Precision 370
SW2005 Pro SP 1.1
XP Pro SP2.0
Everything is going into the right project folder- in fact they are going into the same folder as my previous checkin- which I had no problems with.
Rebecca
Rebecca
