Return Fan Required?
I have seen several different mechanical room configurations...some with a return fan(s) and some without. It seems that most of the larger systems have a return fan.
These design variations have led me to several questions and I thought I would pass them along to the pros:
Under what conditions does a building require a return fan?
If the supply fan is sized large enough, does that eliminate the requirement of a return fan?
Can exhaust fans be used in lieu of a return fan while the economizer is being used?
thanks!
new2hvac
thanks!
new2hvac
RE: Return Fan Required?
