Estimate Weld Cost
Estimate Weld Cost
Estimate Weld Cost
Hi all.
I am working on putting together a pricing program for our sales department that would allow them to enter in the dimensional parameters for venturis that we sell and obtain an estimate of our cost to manufacture.  Dimensionally, it was easy to compute the weight of the unit, but when it comes to estimating weld and machining costs, I am at a loss (both procedures will be done outside of our facility).  Do any of you know of a program that estimates weld costs?  I found one, e-weld, but it does not include TIG, only MIG.  Is there maybe some general rule of thumb that would correlate weld type, joint type and material thickness?  Any suggestions would be greatly appreciated.  Likewise, if anyone has any suggestions on estimating machining costs(mostly bevelling for buttweld connections), that info would be much appreciated as well.
Thanks in advance!
RE: Estimate Weld Cost
You might want to take a look at this one also.
"Design of Weldments" by Omer Blodgett.
You can find it at the following site under books.
http://www.jflf.org/
Thanks to all of your for your suggestions...I should be well on my way to getting a good estimate...
