making a block?
making a block?
making a block?
hello,
Is there an easy way to make a block, Specifically several surfaces into the one solid block?
thanks,
Callum
RE: making a block?
Make 4 flat surfaces using a sketch and the extrude surface (they have to be separate sketches and surface extrustions) and fill in the other 2 with the fill command, then knit it together, that is how you can make a surface block.
If you want to make just a solid block. Make a sqaure sketch and extrude it.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
