Wiring from VFD to Motor
Is there any special consideration one needs to take into account when wiring up a 480V motor from a VFD. I know distance is a factor but is there a need to use something other than 600v conductors?
RE: Wiring from VFD to Motor
Special cables with multiple ground conductors or shielding are often recommended to reduce RFI coming from the high frequency components of the VFD output waveform. A good ground conductor is essential. Okonite C-L-X metalclad cable now comes standard with three ground conductors and makes an excellent cable for VFD to motor applications - there may be others that are similar.
Some type of metallic conduit or shielding is strongly advised and signal circuits should be routed away from this feeder to the extent possible.
I'm sure you'll get some additional suggestions from some of the VFD experts.
"Venditori de oleum-vipera non vigere excordis populi"
