Analysis of Plan
Analysis of Plan
What are advantage and disadvantage if I want to analyze plan (slab-beam-column) by grid or space structures and reduce the torsional stiffness of beam instead of manual transfer load from secondary beam to primary beam.
Thanks.
Thanks.
RE: Analysis of Plan
However you should then provide minimum torsional reinforcement to provide ductility to cover compatability torsion. Also the bending moments in the members will increase.
In some cases, e.g. a beam cranked in plan, torsion is necessary to carry the load and cannot be ignored.
Chris Rohde
Editor, Structural D-zine
http://www.topica.com/lists/Structuraldzine
