White color
White color
White color
How is it possible to make white color (non-transparent) fill? (Choosing white from color table shows and plots as black). I'm using V7.
RE: White color
You have to use a color other than 0. Try number 16 on the standard color table. White (0) has values of 255,255,255. Number 16 has 240,240,240 which is a little grey. I suggest that you edit a number to use 250,250,250 or a variable of those numbers.
Hope this helps
Champ
RE: White color
Thanks, it works
