Fits function in mechanical 2004
Is their a function in Autocad Mechanical 2004 that will calculate hole tol, shaft tol, and min clearance for me if i input the class of fit and size range?
Thanks for you help.
Chris
RE: Fits function in mechanical 2004
If I understand your question correctly, I do not think Mechanical will do what you are asking. It allows you control the "pieces" (hole, shaft, etc..) but will not let you make a all-in-one type of thing.
"Everybody is ignorant, only on different subjects." — Will Rogers
Hello Chris
The problem for tolerances is that there are different engineering standards available especially the RC series.  It would be better to build your own tolerance frame.  I realize this is a pain and this post doesn't help.
John
