Strong or Weak Direction of Sheathing
Is there a strong direction and a weak direction of plywood? In other words, is it important to lay the 8 foot direction across the purlins as opposed to the 4 foot direction?
Is there a strong direction and a weak direction of OSB?
RE: Strong or Weak Direction of Sheathing
For unblocked diaphragms, there is a reduction in lateral capacity. Also see same table.
IBC must have similar table with diaphragm shear capacities.
There is more to it than this, but the bottom line is you are correct, having the plywood face grain (8 ft length) cross the purlin is significantly stronger (say 50% or so stronger) than the other orientation. Plywood thickness, wood species, number of layers, etc. all effect the exact improvement.
www.SlideRuleEra.net
What about OSB? Is it stronger in one direction or is it the same strength in each direction? What about stiffness? Is it the same in each direction?
http://w
and another link for OSB
http://w
