Exploding block
Exploding block
When I explode a block via the modify-explode command and try to select individual objects the whole block disappears and is removed ?
I am using AutoCad R14.
Can anyone explain what is happening ?
RE: Exploding block
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
RE: Exploding block
The block could be on a special
layer.
RE: Exploding block
Pramod
