AISI Material Properties
Heya,
I'm after the Mechanical properties of AISI 4140 shafting:
1/ UTS Stress
2/ Yeild Stress
3/ Endurance Stress
The shaft i'm designing will be no bigger than Ø100mm
Thanks very much
Greg
1/ UTS Stress
2/ Yeild Stress
3/ Endurance Stress
Thanks very much
Greg
RE: AISI Material Properties
For 250 BHN
Tensile 123000 psi
Yield 99000 psi
Endurance limit assuming 55 percent of Tensile
is 67669 psi.
http://metals.about.com/cs/properties/index.htm
Good luck
Thanks again
Greg
