Delete Sheet in excel
I'm trying to write a code to copy a worksheet, do something and then delete it. Problem is I get this prompt before the sheet is deleted:
"Data may exist in the sheet(s) selected for deletion.To permanently delete the data, press delete."
How do I get my code to avoid that prompt or automatically accept it?
Sub Macro1()
    Sheets("Template").Copy Before:=Sheets(1)
    xxx
    xxx
    Sheets("Template (2)").Delete
 End Sub
regards
Mogens
RE: Delete Sheet in excel
A very primitive workaround could be to create a new workbook with the copied sheet and then delete it.
Something like:
Sub Macro1()
    With ActiveWorkbook.Sheets("Template")
        '.Range("C3:E7").ClearContents
        'xxx
        'xxx
    End With
    ActiveWindow.Close (False)
 End Sub
HTH
_LF
Hello mgp,
to avoid such prompts, try to insert the following command line just before your "delete"-command:
Application.DisplayAlerts = False
I hope it may help.
Good luck !
Thanks BurattoN
Works perfect
Mogens
And then put its converse just after your "delete" command, especially if your code is still under development.
