Machining Cell Manufacturers
I'm looking to set up an automated machining cell which will do the following;
-Cut Pipe, Diams 3/8"-8"
-Chamfer inside and outside both ends
-Thread inside
-Stamp part
Does anyone know of a machine manufacturer capable of making such a unit?
-Thread inside
-Stamp part
RE: Machining Cell Manufacturers
http://www.atsautomation.com
Fill what's empty. Empty what's full. And scratch where it itches.
Thanks for your response.
I've gone and checked out ATS Automation and have been on their site before. Great lead, not exactly sure they've got what we need and at the cost we need it. We're producing fairly low spec product and a whole lot of it.
Aamoroso,
Thanks for the invite. This is exactly what I've been working on. Finding different machinery and setting it up in a cell with simple sensors and plc's.
I really like the end quote, great advice.
We also use lathes and yes, for our larger sizes, the cycle times make sense, however, our screw machines will out perform the CNC for smaller parts.
I'm wieghing many options at the moment, CNC with a bar feeder is one of them.
Thanks for the input.
http://ww
What type threads do you need?
Are the threads feed thru or from each end?
We did essentially the same operation on an old Oster Pipe Machine. We cut beveled amd machined the ID of up to 6" Sch 40-160, but could have easily threaded it.
I'll be in touch.
Thanks.
