Wasted Spark Ignition systems
I wonder if anyone can help/confirm the following for me.
I'm quite happy with how the above system works when all's well, ie complete circuit. But, the question I need answering is this... When we go open circuit on 1 plug/lead I say that the other plug will fire and will fire the same (ie Negative or Positive) polarity spark as it was previously?
I've reached the conclusion that in order for this to be true the circuit must be completed somehow, either by finding its way back into the coil via any means possible (through the vehicle body to the Ignition terminal side of the Low Tension circuit and then "Track" through the magnetic field in the coil back to negative)? Does this sound feasible?
When I 'scoped this using a DSO I found that the spark remains neg or pos charged (as previous) and appears to contain some of the voltage (opposite polarity) of the U/S plug? True?
I also 'scoped what appeard to be pressure fluctuations in the coil! I'm assuming that's what I was seeing as the pressure couldn't be dissipated through the other plug/lead as it was open circuit?
Any help would be much appreciated. Thanks
RE: Wasted Spark Ignition systems
I thought that this might be the case. Do you know if it also damages the Low Tension side, especially with reference to the Transistor and capacitor?
Ron
