WQT for ASME IX
WQT for ASME IX
A welder already qualified with API 1104 (pipeline welding), did the welder shall perform WQT for ASME IX (station piping) in the same project, if all the essential veriables are the same?
If I want to ask the welder to perform new WQT according to ASME IX, what clause should i say?
RE: WQT for ASME IX
If the requirement is as per asme, you have to qualify again to asme section 1x
RE: WQT for ASME IX
RE: WQT for ASME IX
RE: WQT for ASME IX
er
RE: WQT for ASME IX
If not, you should be OK. But if different inspection requirements exist, then you would either have to test the coupon to the requirements of Sec IX or retest.
Gerald Austin
Iuka, Mississippi
http://www.weldinginspectionsvcs.com
RE: WQT for ASME IX
The Purchase order for the testing has to specify both
Codes.
er
