run-time error '13'
run-time error '13'
run-time error '13'
I'm getting a run-time error '13' when running through a For Each/Next loop.  What is a run-time '13' error and how can I avoid it?
RE: run-time error '13'
I generally don't pay much attention to error numbers, preferring the description instead.
If you could post the error description, and the offending code, it might be helpful.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
Below is the section of code that's crashing.
For i = 1 To 5
    If i = 1 Then Name = "MESA2_UX1100"
    If i = 2 Then Name = "MESA3_UX1400"
    If i = 3 Then Name = "MESA4_UX1500"
    If i = 4 Then Name = "MESA5_UX1600"
    If i = 5 Then Name = "MESA6_UX1700"
    varCodeValues(0) = Name
    Call SelectAll
    MsgBox Name & " = " & objSS.Count
        For Each LineObj In ThisDrawing.ActiveSelectionSet
            stPoint = LineObj.StartPoint
            endPoint = LineObj.endPoint
        Next
When the program crashes, it has the last NEXT highlighted and the error code and "Type mismatch".  Even if I take out everything in the For Each loop, I still get the error. The message box shows that I have many lines in the selection set (it's AutoCAD VBA), but I can't get through the For Each loop.
What type is a LineObj and does that object type exist within a ThisDCrawing.ActiveSelectionSet object?
Although not necessary, I would also suggest that for code readability, you explicitly identify what the 'next' refers to.
CODE
For i = 1 to 5
   For Each LineObj in ThisDrawing.ActiveSelectionSet
   Next LineObj
Next i
Good Luck
Thanks for the code readability suggestion.
Yes the LineObj is viable.  I put the message box right in front of the For Each statement to determine how many LineObj's were in the selection set.  There is nothing else but LineObj's on that layer, so I know the number in the selection set is the number of LineObj's.
What type is LineObj?  How have you dimensioned it?
What type is ThisDrawing?  How has it been dimensioned?
Additionally, but a long shot, how are stPoint and endPoint declared, and are they of the same type as the corresponding LineObj properties?
Good Luck
Dim stPoint As Variant
Dim endPoint As Variant
Dim LineObj As AcadLine
I didn't dimension ThisDrawing since it is the reference to the current document.  I have used these objects many times before in this same program and they work.  I have used the same For Each loops with the same objects and it works.  That's why it's so confusing on this particular one. It works on another file so it must be something related to the file I'm trying to extract the data from.
At this point I would look to version incompatibility at the document level.  I am guessing we're dealing with AutoCad? here, and is it possible that the version of AutoCad used to create the document in which this program fails is different from the version of AutoCad that you normally use, or the version that your program is expecting.  It doesn't fail in other documents because different version of AutoCad are not in play.
For example, it may be that the program is expecting a LineObj as defined in AutoCad 2005, but the document was created using AutoCad 2004 so the definition of the LineObj object is different.  That could result in a type mismatch error.
This could be caused by an early binding to the LineObj type (dim LineObj as AcadLine) but a late binding (not dimensioned) to the ThisDrawing object resulting in two different AutoCad object definitions.
Good Luck
This is unrelated to the error, but all those 'if's are pretty processor hogging.  CASE is usually a more elegant solution for a selection.
