Foaming Caustic
Foaming Caustic
I have recently had problems with caustic foaming in a 10% w/w caustic scrubber removing trace quantities of chlorine from air. The problem appears to be temperature related but I can not find any theory or data behind the phenomena to calculate the operating temperature that will prevent the formation of foam.
Any ideas ?
Any ideas ?
RE: Foaming Caustic
I know that this is not a direct answer to your query but I thought you might want to consider the solution concentration in your investigation (if you haven't already).
RE: Foaming Caustic
RE: Foaming Caustic
The problem was solved by temporary raising temperature by steam addition. My question is regarding any relevant theory to predict at what temperature I may start foaming - a quick look in Perry & a search on the net has not given any useful answers.
