losing "Component Placement" window
I use Wildfire with the model window full screen.  Recently, during component assembly, when I go to spin my model my "Component Placement" window gets covered by the model window.  So, I must then shrink my model window to pick the edge of the "component placement" to get it back on top.
Used to work fine.  I have no idea what changed.
Any ideas ?
RE: losing "Component Placement" window
This happens in pro/e 2001.  I usually toggle it on and off then it reappears.  It's extremely frustrating when I'm working on a large assembly.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
Do you trust your intuition or go with the flow?
Shoelace,
If my memory serves me try locating these two config file options:
Comp_assemble_start
constrain_in_window
I'm not using WF so I can't tell you if they're an option but they need to be set.
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
Thanks Heckler.  Actually, that's not really what I was after although it's a good tip to know.  My problem is losing the little box that contains the assembly constraints - eg mate, align etc, which in Wildfire is called the component assembly window.  I imagine the problem is not an issure in Pro/E 2001 because usually you don't work full screen.
