Do you have idea to arrest the leak???
3/4" pipe has leaking from half coupling which is conneting ot headers.
Do you have idea to arrest the leak without use sealant injection box?
* Fluid is Ethylene oxide with some gases.
* Pipe material is alloy steel.
Note:
the fluid is gases and harmful/danagerous.
Note:
RE: Do you have idea to arrest the leak???
Comeback with some header sizes and pressures and temperatures.
Where is the leak?
What are the other gases?
Pressure= 17 kg
Temp.= 200 deg.
gases= CH4+O2 + Ethylene Oxide + ethylene + water
Steven van Els
SAvanEls@cq-link.sr
