Mating a flat bracket to a loft surface
Its me again.
Any tips on mating a flat bracket to a mulit cross sectioned lofted surface?  I tried using 3 points to the surface but on the mated points always protudes into the surface.  Urggg.
thanks
RE: Mating a flat bracket to a loft surface
Sometimes the best thing to do is setup a plane or axis for mating.
Fill what's empty. Empty what's full. And scratch where it itches.
I agree with aamoroso ... except that I would say most times
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
To get a plane tangent to an organic surface...
  1. Place a point on the surface.  I prefer using a 3D sketch with a point constrained coincident with the surface.  Add other dimensions and constraints and reference geometry as desired.
  2. Create an axis through the point and normal to the surface.
  3. Create a plane through the point and normal to the axis.
I could be the world's greatest underachiever, if I could just learn to apply myself.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
