Anyone having Resolution Problems with STL Files from SE
I am having some components rapid prototyped and saved the part files out to STL format. My sales rep from the prototyper called me and said that the part was very jagged shaped and the holes were hexagons instead of round. Sounds similar to the View Resolution issues in AutoCAD. Is there a way to check the STL file after saving to make sure that it appears as my Part drawing does?
RE: Anyone having Resolution Problems with STL Files from SE
--Scott
For some pleasure reading, try FAQ731-376
