Imported Surface
Imported Surface
Hi All,
Is there anyway to be able to due a section view of imported surfaces?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Imported Surface
Select the plane you want the section view, open a sketch, use the Intersection Curve tool in the Sketch toolbar to convert the entities of the surface where it intersects the sketch plane.
You can use this tool to generate loft sections of an imported surface.
You can also use this tool to create a curve where two surfaces intersect one another. Select the Intersection Curve, then Ctrl-select the surfaces that intersect. A 3D sketch will be generated with a spline where the surfaces intersect.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
