Linux serial communication => nul characters
i programming (c++) a communication application using struct termios. the communication runs but the character 0 (ASCII NUL, binary 0) will ignored, always and at both streams, input and output. the communication port is /dev/ttyS0 (PC-Com1).
the essential configuration of the port is setting on "raw" (non-canonical, ...) and all input and output options are disabled (no parity checking, no OPOST, ...).
what can i do to transfer the nul character correctly??
thanks all!!!!
hostbuster
RE: Linux serial communication => nul characters
I cannot c++ but I have done some comm applications: is it possible that your application considers nullce as field delimiter? Can you perhaps change the null to some least frequently used character instead of it just before the transmission? This is not an exellent step but works.
m777182
Hi m777182,
thank you for your reply. That was my first self written communication program under linux. In raw mode nul characters will transferred. The fault was between the ears :(
Now i can say (for interested programmers and beginners): programming serial communication for linux is very easy!!! easier than for windows!!!
thank you and best regards!!!
