Part pattern in assembly
In SW 2004, if you had a pattern in an assembly, you could double-click the pattern in the tree, and the numbers used in the pattern would show up in the working area.  For example, the number used for the distance in the pattern, as well as the number for the quantity of parts in the pattern would show up.
Sometimes assembly configurations have the same part in a pattern, but with different distances/quantities.  By double-clicking the pattern in the tree, then double clicking the number in the working area, you have a choice of "this configuration" or "all configurations".
It seems this is disabled in 2005 SP 2, or is just not allowed anymore.  I was told that this option was available in 2005 SP 1.1.  Does anyone else have this problem, or is this a bug?
Flores
RE: Part pattern in assembly
I can not pattern a part in an assy. It is greyed out.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
You may have to have the cofiguration being edited in the assy, as the active saved part.
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
Ctopher: it can't be grayed out I don't think:  In assembly: pick part, hold CTRL button, and pick edge then go to Insert > Component Pattern > Linear Pattern.
Corb: Both the assembly and the part are saved.
I can make the pattern; the problem is when I double-click the pattern in the assembly-tree, the numbers don't show up in the working-area (for lack of the correct name, the area to the rightt of the assembly tree).
Flores
... but did you save the part with the config (that you are trying to change} activated. In other words, when you open that part, do you see the config you are trying to change?
The part doesn't have configurations in it, the assembly does.  For example:
 Assembly configuration 1:
   Part A: 3 Instances 5" apart
 Aassembly configuration 2:
   Part A: 4 Instances 6" apart
 Assembly Configuration 3:
  Part A: 2 Instances 12" apart
In 2004 you could change the quantities/distances for "this configuration" or "all configurations".  In this example, I could double-click the 5 and choose "this configuration" and change it to 6, 12 or whatever for the distance.
Flores
