C profile spring
C profile spring
C profile spring
I am looking for a commersial supplier of C profile  springs shaped like spring pins but of thinner material.
Size 20mm (0.75") dia
     40mm (1.5") long
     0.5mm (0.02") spring steel
Application is to clip stack of sheets 20mm thick.
Would like to try a few sizes before settling on final size.
RE: C profile spring
Did you look for paper clips? there are some about this size. Usuallu you can find such attached to a writing board used buy students.
