Brazing Substitute
Brazing Substitute
Dear all
I'm looking for a brazing substitute.
Pls. tell me if Ultasonics can be used to braze/weld two copper pipes to make an HVAC system.
Brazing technique that we are using is of a conventional type. Can you help me in updating myself with what are the latest techniques available for in the field of BRAZING.
Also I want to know if anyone is using Brazing stations running with the help of water. Somewhat similar to Fuel -Cell technology. Where water is the input and Hydrogen ions gets dissociated through a membrane and re-unite with oxygen generating heat and fire for Brazing the pipes.
Thanks !
MANISH
Thanks !
MANISH
