Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Since using forums in my early days 10 years ago in CompuServe, one had to log back on and sometimes wait days for a response. Now I get a response e-mailed to me which I can click a link and go right back to exactly where My post was..."
Geography
SacreBleu (Structural)
7 Apr 05 23:48
At the office where I work, the standard double top plate splice calls for total of 24-16d nails. The usual IBC or UBC nailing schedule calls for 8-16d. Does the nailing schedule imply 8 nails each side of the splice, total of 16? That would be closer to the 24 (which is probably a result of some cases of high chord forces).
UcfSE (Structural)
8 Apr 05 10:58
I've seen the requirement for 8 nails and really couldn't tell if that was meant to develop a certain force or not.  I would use 8 as a minimum and specify more if forces required.  I interpretted the code to mean 8 on each side like you said.
Helpful Member!  whyun (Structural)
8 Apr 05 11:19
8-16d nails for double top plate splice is specified in the nailing schedule in the UBC and CBC (Table 23-B-II-1).  This is a minimum nailing unless design forces warrant a greater resistance.  The nailing is intended to be at "laps".  You don't always get 8'-0" long pieces to obtain a perfect 4'-0" laps each side.  If the pieces are 12'-0" for example, apply 8-16d at the 4'-0" lap, and apply 16d @ 16"oc at the 8'-0" portion as a minimum, unless design forces warrant a greater resistance.  For 8'-0" pieces (typical in residential construction), 8-16d can be applied at each side of splice.
8 Apr 05 22:53
whyun,
OK, now I get it. The detail at my office calls for spacing the nails very tight together, and in 2 rows, concentrated close to the splice. Your explanation makes a lot more sense. Gave you a star.
Close Box
Join Eng-Tips® Today!
Join Us             Close
